Technical MPI 40mm TB????
Olli3 D
Tamed yellow beast
just been looking on the cbf site and ive seen lotsa talk of a 40mm throttle body for the sei sporting mpi,
has anyone got one and where could i get one from???
thnks
.oli.
fingers99 - are you saing you have got one?
or are you saying that you are selling one?
ive you managed to get one for 15quid where did yu get it from????
.oli.
my bad, i thought the inlet on the plenum on the MPI was 43mm but it is only 39mm.
FYI, the inlet on the P75 plenum (without spacer) is 48mm. So if it were me i'd bin the Sei MPI manifold and fuel rail, and fit the P75 kit with a 16v TB on it.
Or go completely barking mad and put the 48mm Dell'Orto TB from a K series on! But that is, way, way, bigger -- almost certainly too big.
My only real concern about the P75 mani (in this useage ;)) is that you've either got to faff around with the fuel rail mounts, to make the Sei injectors fit (just as I'm having to do with Blue's new mani/plenum) or use the P75 ones (which the Sei ECU may object to).
