- Joined
- May 8, 2005
- Messages
- 9,053
- Points
- 1,538
do you need to be able to open up the tailgate for the car to pass the MOT?
also anything else i should know before i book my car in?
bulldog5046 said:do you need to be able to open up the tailgate for the car to pass the MOT?
yes, the tailgate is required to open. the mot tester needs to check wheel well, spare wheel if fitted, floor and rear seat belt anchorage. and unos tend to go around the wheel wellsbulldog5046 said:well it isnt impossable to open, just been reading the MOT test checks in the haynes and it says both drivers and passenger side doors must be able to be opened and closed properly from inside and outside of the vehicle.....
sooo...anyone care to say if the tailgates a passenger door?
how do they check the spare wheel and well?Hellcat said:I've never had my boot opened for an MOT - and I've put a fair few hatchbacks through MOTs
if the spare wheel is fitted, it has to be road worthy. if not fitted, not checked.The Negotiator said:I thought the spare wasn't an MOT item? (even if fitted)
well, they can only write on the certificate the actual clock reading at time of test, so i would temp fit the old ones in.bulldog5046 said:just add on here, what about my clocks? i fitted UT clocks and they display 106,000 miles which would make my car look as if i had done 32,000 miles in a year! do i just have to put the old ones back or can i tell the garage and they will make an educated guess at what i've really done?
