Dont think there is a guide. You need to remove the front bumpre in order to remove them. Once you've done that, then its just a case of unbolting the 3 10mm bolts that attach the geadlight to the car. Two on top, and one at the front. Then disconnect all the wireing and then the headlight will just lift straight out.
With reguards to the angel eyes, yes that is in essebnce all you do. Depending on which make you buy, you may need to make some furthe connections if you want the angel eyes to come on with youe sidelights, but everything else is just push to connect jobbys.
Hope thats of some help.
Good luck
Alan
