distortedmemories
- Joined
- Mar 2, 2008
- Messages
- 8
- Points
- 7
Ok as i've said in a previous post my door now fails to shut due to the mech not working/engaging. so decided i would replace it! however when i went to the scrappys there was only a 5door model, so was wondering if any of you knew if the mech on a 3 and 5 door are similar enough to work? (presuming its only the rod sizes that are different?) it also appears this mech has/had central locking as it was wired in. But presumably it would work just fine manually? also im not sure how the key barrell fits/works in all of this... any help would be appreciated as it appears to be quite a tricky job (removing and re fitting all the plastic guides.
