Hi, just wondered if anybody could shed some light on the matter.
But basically, 9 out of 10 times the gearbox will go into reverse fine, but every now and again you pull it back into reverse and it will kind of stick before its fully engaged, and just grind when you lift the clutch.
Gearbox oil level is fine, does it with the engine off as well as on, so I can rule out the clutch.
Ive tried adjusting the cable, but it doesnt seem to make any difference.. is there a proper way of adjusting the cables?
All the other gears engage perfectly fine, no problems at all.
