- Joined
- Jul 9, 2007
- Messages
- 79
- Points
- 17
I have a MK1 1.2 16v 85sx which I have just repaired from a write off and is at the MOT station at the mo.
If I was to relocate the battery to the boot this looks like it would give quite a straight path for a home made induction kit to go straight to the nearside headlamp.
If I was to do this and de-cat as well. On the standard ECU would it run lean because of more air going in and out and cause engine damage?
On the Cento forum alot of people talk about the 'Mcritch' (spelling?) chip. Does this alter timing and fuel pressure?
Does this 'chip' fit the Punto? Would it be wise to fit one?
Where do I get one?
I hope I havent got the wrong end of the stick with N/A tuning. I'm just going off the turbo magazines that I have read that say, if you put more air in you need more fuel or problems will occur.
With the 1242 16v motor. Has anyone stuck this head on a Stilo 1386 16v?
The reason I say swapping the head is because of all the electrical gubbins on the Stilo (fly by wire).
Could you put the MK1 Punto intake and exhaust manifolds onto a 1386 16v? Are all the sensors, intake and exhaust ports the same shape and size?
Thanks in advance for any answers.
Nathan.
Where do I get one?
Nathan.
