General Mk1 fuel rail connections
panda-sport
Essex Panda's R Us
Basildon, Essex
I'm fitting a 1242 16v from a mk1 punto 85 into my car. Can anyone tell me if the top connection is the fuel return and the lower fuel in, or tother way round? :eek: cheers Damon
arc
this is where i stand
Manchester
should be obivous from looking at the fuel rail setup i would've thought, the fuel in will be the one with the regulator inline
OP
OP
panda-sport
panda-sport
Essex Panda's R Us
Basildon, Essex
Cheers arc, but your talking to a thicky here :eek:
Some pics of the rail
cheers Damon
I've just taken delivery of a 16v engine to pop in my punto...
I must admit I can see your problem...the fuel rail doesn't give a hint as to which one could be the feed. I've checked the Haynes and that's really unhelpful. Just points towards the 2 lines saying feed and return with no indication as to where they should go :confused: .
I'll dig out the workshop dvd later and see what I can see - if its as useful as Haynes, nothing!
At a guess I'd go with the straight feed in but, it could be the angled one.... :chin:
Derby
cheers Damon
Looking at the picture the fuel rail on that engine is exactly the same as mine, just remove the fuel lines (squeeze the tabs together and pull) they will only go back one way, It's impossible to get them wrong. I thought the same thing as you before disconnecting mine.
The top line (i think is inlet) has a male pushfit connector, and the bottom one (return i believe) has a female connection.
However it does state in the haynes that only the more recent 16v engines had this fool proof pushfit setup, so some of the older engines may be easy to confuse.
Thanks I need this info too :)
OP
OP
panda-sport
panda-sport
Essex Panda's R Us
Basildon, Essex
cheers, trouble is my engine is out of a scrap car and if I'd used a wide-angle lense on that photo you would see the other end of those lines where they have been cut. The car this is going in does not have this type of connector.
I looked at the pics on eper but it uses the 1242 8v pic as they have the same lines as the 16v, however the flow arrows on this match your thinking.
cheers again Damon
Derby
cheers again Damon
Yeh usually a male end from any tank is flow, and female is return (i actually learn't that at work :eek: lol).
Glad i could help anyway :) and good luck fitting the engine :)
