With reference to the enclosed picture.
Remove A,B,C then to remove D,E you need to "drop" the steering wheel down to get at them (you may also need to remove the steering wheel cowling, 2 small screws at the back of it underneath nearest to the dash) then remove F by opening the fuse box cover, this one holds on the air duct) and unclip it. Then the whole dashboard assembly can be moved forward off its clips and move it out to the right towards the gear stick, then you have access to the screws holding the "dials" in place , unplug the wiring looms and it all should pop out nicely.
Refit it all by reversing the procedure.
