Bravo MES cannot change oil parameters
salvodipa
hi , i'm new but i know something about multiecuscan , i used sometime for the previos car "Alfa 147" and also for my actual car " Fiat Bravo Diesel 1.6, 2009"
The Issue
i have got warning light oil flashing, "change oil",
i had the same issue before so i used MES to reset it!
now when i connect by MEs i cannot change oil parameters!
i'm using Elm 327 setting for interface!!
can you help me? thanks!
more details:
i don't have data on Date of last Oil Change...
even Oil change service number...
Try This procedure:
Switch the ignition to position one but don't start the engine.
Press and hold the accelerator.
Tap the brake pedal 7 times then continue to hold the accelerator down for a further 60 seconds.
Release the accelerator and turn off the ignition. Wait 60 seconds.
When you turn it back on the oil warning should be reset.
