Marelli ECU Test and Repair
JDN
I had a problem with the Magnetti Marelli ECU fitted to my Fiat - one of the pins in the ECU connector was damaged so the engine was immobilised (VPS car/padlock warning light on) and the OBD2 reader couldn't talk to the ECU.
Out of a list of 10 different ECU repair companies only one said they could test my unit. Either there wasn't enough Marelli ECUs going wrong to justify developing a 'test harness' or the ECU case was too difficult to work with.
Car Electronics UK replaced the connector, tested it afterwards and no programming was required after refitting it. £220 inc VAT plus £10 return postage.
www.carelectronicsuk.com
Recommended!
