Hi there,
I had exactly the same problem with my R reg Marea Weekend 125. Great off the line, but get it on the motorway and it struggles to keep up to 80 except after a long downhill stretch.
The problems have been 3 fold. First off, change the fuel filter regardless of history. Secondly check all the plugs and sockets relating to the accelerator pedal and the throttle body connections and also the MAF, as this type of engine is flyby wire (no throttle cable). Thirdly and lastly for this fault, the MAF may need cleaning. It is not easy and requires special tools, which are available at Halfords. I have done all of this under advise and now the car runs like a dream.
The likely hood of a blown turbo is unlikely as these normally produce either a loud untoward noise or lots of white smoke from the exhaust. If you can here a smooth whistle under power, then the turbo is fine.
The Engine is reliant on a combination of electronic peddle demand signals, and mixture settings given as a result of the sensor readings throughout the engine. If any of these are wrong, then the engine is being told lies about what is happening to it and the ECU just gives, what it is being told. An old computer adage springs to mind. "**** IN, **** OUT"
Good Luck and keep me posted
Ravenrigger
