GEAR BOX REMOVAL
You will Need
A decent ratchet
A breaker bar of some sort
Ratchet extension bars
The following sockets, 10mm 13mm 15mm 17mm 18mm 19mm
The following spanners, 10mm 13mm 15mm 17mm 18mm
Allen keys
A hammer
Long flat ended screw driver or similar to lever with
Tin of WD40
Long tie wraps, to tie items up with
A good jack
Minimum of 2 axle stands
A hoist, or some method of supporting/moving the weight of the box
The facilities to make lots of cups of Tea/Coffee and a few bacon sandwiches.
You will Need
A decent ratchet
Allen keys
A hammer
Tin of WD40
A good jack
