Hey,
My dad was having trouble with his Mk2 JTD so I borrowed some diagnostics equipment from a guy at work. I managed to sort out the problem (which was a new cold start controll box ) but whilst i was looking at the dignostics, I noticed that the MAP sensor was showing a constant 255KPA and the engine temperature was contantly 216oC.
I disconnected the MAP sensor wich made the engine light come on, and the reading stayed at 255KPA so i am assuming this is a default/fail safe setting? and there is a problem with the MAP sensor?
The engine temperature is also weird, because the gauge does not show it overheating, and the cooling fans are kicking in no problem when just over 1/2. So why am i getting this reading??
I tried the dignostic thing on my Seicento and the MAP sensor was going up and down with the accelerator and the temperature started at about 5oc and went up (which i'm pretty sure is what is supposed to hapen?)
Any help will be greatfully recieved. I'm only learning when it comes to playing with cars
Lizzie
Lizzie
