puntodad19
- Joined
- May 1, 2019
- Messages
- 177
- Points
- 101
Mr fiat.com sns shop for parts are known about...
Parts exploded views are great but some do not list various nuts and bolts etc...
Punto Evo active 2010 1.2 8valve petrol...
Might someone know the size/thread etc. for the two torqes head bolts that hold the front brake caliper *frame*, the bit attached to the front hub ( with the wheel bearing in it, held to the front suspension strut by 2 larger bolts and nuts ) that the break pads it into and the caliper fits over via two slide pins....
It's the two torqes headed bolts I am after, size, thread pitch and part numbers please.
Also part numbers of the two nuts and bolts that the hub is bolted to the strut with, and the bottom ball joint pinch bolt and nut please.
I can get new pads and discs etc., It's the nuts and bolts I need *in my hand* before even attempting to remove the old bolts etc., Possible disc renewal for not coming up...
Thanks guys, help greatly appreciated....
