NEED SOME HELP, Bought the alloys with some new lug nut as well but a bit longer probably 2-3mm difference, so after putting all of them on the car tried to run the car to have a bit of enjoyment but apparently every time i go reverse and in 1st gear the car is just moving but won't allow me to move about a metre or so
and figured out that the new lug nut are far to long and touches something inside the brake thigy :bang:, so I've decided to return the old lug nuts in to the alloys (the ones that came off from the stock alloys) everything was falling into the right place except two things, one of the lug nut on both each side of the front wheel won't let one of my lug nut to screw in and every time i try to put it in, when it came off the end of the lug nut screw is a bit messed up well the thread is stripped. and I'm currently running the car with 3 stud on each front wheels. all of them were fine except one hole on each front roter, what do i need to do?
