Will a 2016 Fiat 500x 2.4L shut itself down if there is low oil level or low oil pressure? I've heard that it will shut down under these conditions to protect itself from engine failure. thanks, gregjo1948
I thought there might be a warning light come on but not to actually shut down. I have read that this engine is prone to excessive oil consumption. With around 40K on it, I need to add a quart at about 3K. I run synthetic oil and change oil and filter at 5K. thanks for your reply, gregjo1948
No, imagine if it decided the engine was low on oil when you were in lane 3 or 4 of the motorway doing 70mph and it shut down....
It has an oil warning light but don't rely on that,it may be too late if it comes on, check the oil level with the dipstick or with the computer on the dash (if applicable) frequently.
Unfortunately pressure does not have a lot to do with capacity and if capacity is low then pressure goes low that implies there is none, so is really a 'too late' light. Until you get to know average consumption for your vehicle, check the dip stick daily, only takes a few seconds if you are on level ground.
