fletcher7751
- Joined
- May 25, 2011
- Messages
- 70
- Points
- 76
Hi all
My Dobby started making a loud ticking noise from the engine, similar to the noise l had eleven months ago when the crankshaft pulley failed.
The frequency is relative to the engine speed, when changing gear the noise stops, but the engine speed has reduced to tickover, when gear engaged again, the noise is back.
Thinking it was the pulley failing again l took it back to the garage, who have been good in the past, and after looking at it said the pulley and timing belt were fine - timing belt, water pump and tensioner all done 30,000 miles ago, crankshaft pulley 8,000 miles.
They think the noise is from the camshaft area and suspect a valve lifter and are going to do an oil flush and change with filter tomorrow as the first option to see if that helps.
I've found "lifter tick" online but can't find anything on this engine.
I can't find anything in the forum about this either, how common it may be and remedies.
Generally, l've seen some oil additives to deal with lifter tick, has anybody experience with these, and if so which one is recommended?
Looking to try Wynns Hydraulic Valve Lifter treatment tomorrow whether the oil flush and change has cured it or not.
Dependent on the cost of replacing all lifters with labour, the poor old Dobby might not survive.
Any trusted Indy in Nhants or Bedford?
Any advice or guidance greatly received
