Technical lost key codes?
basa99
Hi, i have a code for my ignition keys but i am not sure if it is correct. is there anyway i can find out if the code actually 'fits' my keys?
OP
OP
B
basa99
its the code for the keys which start the vehicle. there is a mechanical code and an electronic code on the blue cad from Fiat? not sure if this is clear? thanks
ponsaloti
CASTLE LOCKS Benfleet
essex riviera
We cut keys to code and sometimes send them thru the post.
So, if you send me your key cut code and a picture of your key, I can tell you if the code matches your existing key (no charge, its 2 mins work). If it does, chances are you have the correct imo code.
I can put your key cut code into my machine and it will give me a preview of the cuts its about to make.
E-mail it to me if you like.
[email protected]
T14086
Forum Moderator
Preston
The immobiliser code, you can check it but depending on model/year of vehicle?
John Dough
I have never had this card with the codes but would like to have them in case of keyloss or emergency ,spoke to the local Fiat dealer he said you can not get them as you have to bring the vehicle in to check this out electronically is this true??
England
No, they be talking jibba jabba.
I have a 53 plate Ducato JTD but all I have is just the one key, how do I go about getting a spare? I dont have a master key either. I could put a picture up or mail it to you if that helps. I have central locking/
Thanks (y)
maingate
Tyne and Wear
This has been bugging me for a long time also.
I have a 52 reg Ducato with only 2 black ignition keys. It does not have central locking.
Should I have a red key as well?
T14086
Forum Moderator
Preston
What they mean is you can obtain the codes through them however you must prove the vehicle is yours....for obvious security reasons!
