harrybozing
- Joined
- Feb 29, 2012
- Messages
- 19
- Points
- 4
Hello again everyone,recently I posted about how I could remove the drivers airbag to enable me to change the comm's 2000 unit as I had a problem with my lights staying on all the time,horn inop,etc'. The comms unit made no difference,and eventually I gave up checking and booked the car in to M & M motors who are an independant Citroen specialist based in Holmfirth in Yorkshire. As a result, my problem is now solved, the fault lay with the main fuse box in the engine bay( located underneath the screen water drain). There are internal relays in this fusebox/bsm and some of them were not switching which led to my problems. A visit to my local breakers found a similar unit,swapped over,problem gone. Many thanks to M&M and my son for all his invaluable help. Hope this may be of use to others with similar problems.
