Unless the LED units you use have resistors built into them (some do, some don't).
However all bulbs you use on your car in the UK need to be E marked. LED replacement units are not, and as a result your Car will not comply with the UK vehicle lighting directive and you'll technically be breaking the law
But if you get a decent LED unit the law probably won't bother you
I was just looking to replace the side/daylight ruining bulbs because the 500 seams to have an insatiable apatite for them. I will see if I can find some with resistors that don't look blue when there on.
