LED dash bulbs please help!
xswiftyx
Hi these dash bulbs, currently on eBay as online shop is under construction. I want to know if you lot know what fiats these fit. I'm told punto mk2 but want the whole list if poss. They are the 5mm twist lock style. Here is a pic of them. Hope you can help! Cheers in advance
Hi
I know they fit on fiat tipo with analog table, fiat uno, panda and other older types.
I am not sure for new models.
they easily fit any car if you have a soldering iron and some wire :)
and they're really cheap at m99.co.uk (as are most LEDs and car bits)
Excellent stuff guys thanks for the help! So do they fit the brava or did you have to take the soldering Iron and wire to it?!:cool:
Anyone else that know what other they fit would be great!
well take your speedo clocks out, and take the bulbs out.
You don't nescerslilly (worst spelling ever) need to use those ones, just get some led's and a resistor to protect it (then it'll last forever) and solder them into your existing bulb holders.
if i remember correctly when you take the instrument panel out you can reomve almost all the bulbs without taking anything apart, and those LEDs you have pictured are designed to fit in the holes perfectly.
but be warned they look crap, very dim and the light doesnt spread so you end up with a few circles of brightish light and not much else. plus the bravo/a is back lit so it suffers even more from the dim light.
i've got a box in my garage with many LEDs exactly like that, even ones that change colour, i used to sell them to local kids and fit them for a few quid extra, but i stopped doing it because people were less than satisfied with the amount and spread of light. they dont do what they say on the tin. bulbs are needed to get enough light, LEDs just arent bright enough and the light is too directional, whereas a bulb spreads light out evenly in all directions.
i wouldnt waste your time with them
I sell the blue ones. Much brighter than the standard i think
here is a pic of them in an Astra mk4
They are brighter than they look in the pic
