Technical LCD display too dim..
peterp
United Kingdom.
Hi all
Can anyone explain why the LCD display on my Dash would have dimmed.It's ok when viewed from the side.
Is this a likely expensive fix and what would have caused it in the first place..?
many thanks
Peter.
Fiat Brava owner-no mods!
the bulb behind it has blow, it happens alot.
you will need too take out the inst cluster too change it tho, its not that hard really. :D
uno 1.0ie RAAAWW!
since the lcd is naturally a greeny/brown color if you shine a blue light through it i doubt very much that it will look very blue afterwards.
btw the bulbs fitted are regualar clear bulbs, not green ones.
-=[uno 1.0ie RAAAWW!]=-
-=[trained fiat tech for what it's worth.]=-
This may saound silly but.......
Have you knocked the dimmer switch located on the bottom right near your key?
Just a thought before you start to dismantle your dash :D
Hi Wimmy and everyone.
Its not silly to think that-in fact it sounds just like me!But Its now sorted thanks-was the bulb in the end.
cheers as always peeps
Peter
Fiat Brava owner-no mods...yet!
