Technical Key programming
CIN
Hi
I have changed the ECU in my car because it was faulty and now I need to know the sequence to reprogramm the key so it can start the car.
Anyone know the sequence to reprogramm a new key?
The car is a 2002 Punto 1.2 8v
Joseph
if you've replaced the ecu for a new one then you should'nt have to programme them in because the body computer is the same and this stores the keys...
if it is a second hand ecu i dunno if it can be re-programmed
when you say key programing do you mean the "infra-red" central locking key?
if so... im sure the infra red module in the sunroof panel has its own memory and is not linked to the ecu in any way...
if you read the fiat punto handbook! it says you can only programme new keys when the car is FIRST bought and brand new, in any other case you will have to go to Fiat dealer to programme any extra or current keys, its a way to stop any "theif" re-programming any new keys to your car.
ive just bought my punto, the central locking works "manually" but not via the infra red key remote!!!
