vc_1985
on the dash in yellow its a pic of a key and says code under it it is now permanently on! any one no y?
If you have replaced the chip its entirely possible that its the chip. With my chip the light remains on as the immobiliser circuit is disabled. You can easily check if the circuit has been disabled by disconnecting the key code reader box which is behind and slightly above the fusebox. It has two connectors one which is for the sensor and one that goes into the loom. Disconnect the one that goes into the loom and try the car. If it starts its most likely that the circuit has been disabled if it doesn't you could have another problem either with the immobiliser box or the ECU.vc_1985 said:it stays on all the time ive had my car chipped but it has been fine till now! i went to fiat lol wish i hadnt and said my car isnt safe to drive and should leave it there and that it would cost me 200 quid to fix! i just said its a cinquecento i no its not safe to drive and walke out! they dont no anything!!!!!!!!!!!
Yes, by disabled I mean not working i.e. you have no immobiliser. By disconnecting the control box you will be able to tell. If the car still starts the immobiliser is disabled. also if the box is disconnected the light will not go on.vc_1985 said:the car starts fine and drives and there is no problem at all can the chip of disabled the imobiliser circit?
