Decided to insure the B just for the weekend
and took her for a test Dyno run yesterday to see how her tunning was after the latest changes made, ie New diamond clutch, lightened, balanced 4kg flywheel, new belts and variator change and also removed the 200cel catt.
She feels good and seems to pull well but was suprised at the dyno results..
The Dyno machine hasnt a B in its list so the guy had to put an mx5 for comparison, something to do with gearing I believe and not sure if this makes any difference to the final readings but had three runs on the dyno and here are the videos and results.
The measurements are bhp at the wheels so believe I need to mutiply it by a bigger figure to show engine flywheel output but dont know how, maybe someone can help or know how to calculate this.
From the results is showed her map is off and what seems Bhp is down since my last dyno but here are the results of three runs anyhow.
1st run showed 118
but was running a too rich and dangerous AFR mixture.
2nd run with a couple turns of my fuel pressure regulator to add fuel gained 4bhp -to show a stil low but improoved 122bhp
3rd run after some more turns on the regulator improoved the AF to a safe state and we run a better 125bhp with 148 torque..
I think I,m correct with the bhp measurement at the wheels so the engine flywheel should be more but I dont know how to work out the difference.
So not sure if the results are good or bad..
Have three videos...
http://youtu.be/bTLvuK85U60
