Hi guys,
I've just got a couple of quick questions...
1) How much play in the steering rack should there be when you have both front wheels off the ground and then wiggle one of the wheels? I've replaced all of my front suspension parts (wishbone, struts, springs, drop-link etc) but I've got about half an inch of play at the steering arm which I'm concerned about. There's no play at the steering wheel at all.
2) I've got one of the MOST ANNOYING squeaks ever heard and I can't for the life of me track it down. One idea I have is that it might be one of my engine mounts. I took a picture (from the o/s wheel arch) so that you can see if you think that maybe it's failed.
I'm not sure if it's meant to look like that but I assumed that the bolt should line up with the access hole... no?
Cheers for any help you can give
