B0yCk
- Joined
- Jun 1, 2011
- Messages
- 129
- Points
- 31
Hello,
For some time I face a persistent and nagging problem: my car goes jerky / interrupted.
The show starts just after the engine started to warm up, across the whole speed range (often there are areas that i can keep constant acceleration without jerky). I repeat, ONLY if i maintain constant throttle or accelerate very very smooth / easy it jerks. If you get in the way of stuttering and then accelerate, disappear, but reappears if i keep again constant.
I made several tests and replacement of parts:
- I cleaned and blocked EGR-> no change (EGR functional so I left, I removed the lock plate) - the tester comes out functional
- MAF, just stands in the tester parameters, no symptoms of a dead sensor
- MAP - cleaned
- I replaced the crankshaft sensor (I read that once heated can give all these symptoms-replaced with a genuine BOSCH)
- Changed the fuel filter
- I did a visual test of how the injectors spit, all the same.
- I have no hose broke, no smoke.
- I used over 80% the most expensive fuel at gas stations, the best ones
- i shift over 2500rpm after the engine warmed
- no symptoms of "eating" oil (about 500ml at 9000km)
- no lights on dash, no errors in FiatEcuScan.
- brake switch changed
The only thing I noticed when opening the hood is that I have some traces of oil from the intercooler and intake hose connection (at the throtle body).
Any ideas or opinions are welcome, I have no idea what to check anymore.
:bang:
Car: 1.9 JTD 8v 115bhp
- MAP - cleaned
:bang:
