Technical JTD engine conversion
tan159753
Hi
Something in my Y reg punto standard diesel engine has decided to fall T**Ts up and so basically I need a new engine.
Only problem is I can only find the JTD complete engine from another Mk2 punto. The engines look quite different but how much involved will it be to convert my standard diesel to to turbo diesel jtd?
Obviously I will need the ecu from the donor car as well as the engine but what else is different? Does the JTD have a lot more sensors? Will the gearbox, driveshafts etc fit?
Any input would be welcome. I would be doing the work myself and have access to the complete donor car for other bits and bobs.
Well I am getting the engine from a scrappy so dont really have the option to take everything but they did say you can take whatever it need.
The manifold would come with the engine anyway.
I was wondering if I could just connect the engine up without the turbo??
Oh nuts. The clutches are different, the jtd being 30mm bigger. Most likely the gearboxes are different too.
Guess im gonna have to abandon that idea.
