its service time
its service time
A
andy on blackberry
Right my marea weekend is coming up to service time its a 100 16v for those of you that don't know so what would be the bits I need and what's recommended
From what I can think of its
Oil and filter
Plugs & leads
Is there anything else that I have missed and what parts would be best without breaking the bank
Cheers andy
depends on what the mileage is, but id change (considering i sell service kits to garages all day long)
plugs, oil, oil filter, air filter (i think u have induction kit though) and run some fuel treatment through will improve it a little.
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt have used nuts and bolts :)
yes i have an induction kit fitted
and the mileage is only 43500
and any particular brands recommended
ANDY
02 marea weekend 100sx
current mileage: 43500
status: running great now its been retimed after the inlet cam was a tooth out :)
Bigger is
much better
mods so far:
16" Fiat Coupe 20v Turbo Alloys In Black
factory fit full set of marea mats
Clear Side Repeaters
INXX Bonnet Lifters
Induction kit
Marea ELX/HLX Rear Curtesy Lights
Poly headlights with HIDS & light covers
Sony head unit and working marea steering wheel controls
front fog light switch strip
previously known as: andy_brava_elx
Can't see the point in replacing the leads unless they are creating a misfire. Plugs yes, leads no.
Don't forget new copper ring washer for the sump plug.
Usually you'd be needing to change:
Oil
Oil Filter
Possibly gearbox oil (depends how fussy you are)
Pollen filter (if present)
Wiper blades (if needed)
Sump plug washer
Sparks
Air filter
Coolant top up
Wiper bottle top up
Check:
Wishbones, CV joints, suspension dampers, springs, brake pipes, brake cylinders, shoes/pads, discs/drums, exhaust and mounts, tyres and wheel bolts, bulbs, horn, door hinges (grease), locks, wiper functionality, rocker cover leakage, general leaks.
I'm sure there's more but its a start :)
Longest Serving BOO Member
Stilo (3dr): Mar 06 1.4 16V Active Sport / 28,500 miles
Coupe: Feb 97 20V N/A / 136,000 miles
Oh yes.... Check Tesco for prices of Redex - sometimes they do monster deals on it.
Forte Fuel Treatment I find rather good though. Pricier and its trade only (but can obtain via ebay) but seems to work well in clearing things out, especially for a MOT.
or u could just go mad with it like insy lol
i wouldnt use redex..there are sooo much better stuff on the market now.
and asfor brands. a filter is a filter and they all do the same thing really...although fram and mahle are very well known brands
well glad you mentioned about the gearbox oil i had mine changed about 5000 miles ago when the clutch was changed wasn't sure if people changed it or not
also had exhaust done
wishbone bushes changed
and had a general look over it
mmmmmm hadn't thought about redex or petrol treatment might give that ago since the mot is due end of july
@ insy do you still have your brake disks for sale if so could you text me please
ANDY
Bigger is
much better
mods so far:
INXX Bonnet Lifters
Induction kit
K
7
7K
keval
K
K
6K
Keval
K
M
317
Marcus
M
A
9
859
M
A
551
andyb76
A
