westfielder
Hi, Thanks for looking.
I have a 2001 Punto 1.9JTD
It dies while driving - got it home almost with a few restarts (only 1/2 a mile)
Pushed onto drive. Connected laptop and got
P0191 Fuel Rail Pressure (2)
P1672 Fuel pressure regulator
and the associated descriptions on FIAT ECU scan
I cleared the errors and it restarted. It would Idle If I slowly revved the engine it would run as long as I didn't come off the power - at which point it would die with the P0191 error
I noticed while idling and checking other parameters a number of odd things
Fuel Pressure does not match Desired Fuel Pressure (up to 100 bar difference or more)
Thought maybe that was something to check
I then noticed that Air intake quantity didn't match Desired Air intake quantity. up to double the amount difference.
So 2 different sensors - odd.
Then after a while and engine warm and disconnecting and reconnecting a few plugs it suddenly started behaving. The Desired and actual parameters matched and I could rev the engine fine. Went for a spin 500 yards and all fine.
This morning the wife managed 50 yards before it died.
When home from work I put on laptop and now
P0235 Boost pressure (1)
P0190 Fuel Rail Pressure (1)
all of these are described as sensor and wiring errors and for different systems/parts
Now if I clear the errors it will start but just die within a couple of seconds with just the P0191 Fuel Rail Pressure (2) error- so the problem is getting worse.
I am thinking - is it a bad earth somewhere and the sensors are not reading against a true earth so the voltages and hence the interpreted values are wrong??
Anyone else had similar or could point me in the right direction - I would be very very grateful
The battery voltage is reported at 14.54 or thereabouts while idling
Many thanks in advance
Nick
Nick
