Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 13, 2017 #1 Duff screen pump Never had rear wash ability, but front stopped Diagnosed open circuit Rotten rotten rotten Connector - spade - wires But should seis have a twin outlet or a single outlet? As i found a spare washer tube loose in wheel arch as well....
henseyseries3 Moderator Staff member Parked in the garage Joined Dec 11, 2014 Messages 795 Points 284 Location Birmingham Dec 13, 2017 #2 Depends what year it is, spi Sei has twin pumps like a Cinq Mpi has a single pump with two outlets
OP OP Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 13, 2017 #3 henseyseries3 said: Depends what year it is, spi Sei has twin pumps like a Cinq Mpi has a single pump with two outlets Click to expand... Its a mpi i believe, its a 2002 1.1 setup Ziggy
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Dec 13, 2017 #4 Ziggy122 said: Its a mpi i believe, its a 2002 1.1 setup Ziggy Click to expand... Should be a single pump with two outlets. It spins in one direction for front, reverses the polarity for rear. D
OP OP Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 14, 2017 #5 rallycinq said: Should be a single pump with two outlets. It spins in one direction for front, reverses the polarity for rear. D Click to expand... Thays wrapped up what i need to know Scrappy didnt hav any sei / cuiqs But a peugwot 206 pump has twin outlets and same size intake bore, since it needs new connector i chopped loom off to to cut and shut it - and in thoery - we should have a working spray nozzle setup Just gotta teat pump before i fit it Ziggy
OP OP Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,186 Dec 15, 2017 #6 Well ill share some images from the repair The pump came from a pug 206 / 207 The connectors been cut off and reattached as you can clearly see it was rotten.... But the cars finally got its rear screen wash back that it should of had a long time ago! And yes the pump was shot - it wouldnt work even with terminals cleaned up Ziggy
