Gardener39
- Joined
- Jul 26, 2009
- Messages
- 4
- Points
- 2
Hi folks,
I have a problem with my cinquecento, 1992 1000cc.
Basically if you use the brakes normally the pedal sinks to the floor and the brakes don't work very well at all. If you push the brake pedal quickly and hard the the brakes work better.
After changing the brake fluid and front shoes and disk there is no change and we have also bled the system but still no change, I think it might be the master cylinder is at fault and wondered if anybody could advise on how difficult it would be to change it for a new one? I should be up to the task unless anything like specialist tools are needed.
Any help and advice is much appraciated,
Thanks,
Gardener39
Thanks,
Gardener39
