Continuing with the story, jump forward a couple of years to April 2017 and it was time to rebuild the engine, my favourite job to date!
This started out as a “let’s give the engine a clean” type job that escalated!
Like many of the imported cars Luigi’s engine was covered in a thick layer of oil and dust which made it smell very bad and more importantly seriously affected the cooling, the big plus though was that this inbuilt corrosion protection system had done a brilliant job of keeping things as good as new!
With the engine out and an initial clean of the exterior completed it was strip done time, it all came apart without too much trouble, carefully following Haynes and keeping all the bits catalogued in recycled takeaway boxes!
So, what delights were found within!
The head had cracks between the valves, worn seats, valves and valve guides.
The main bearings were destroyed (see the cause earlier in the Luigi story).
The timing chain and sprockets were worn.
But apart from the odd stripped thread and a dreadful amount of dirt and debris all looked surprisingly good!
The head went to Mark at Motobambino along with a long list of parts required, whilst I got on with the laborious task of cleaning all the remaining bits.
With the head back everything was ready for the re assembly, great job, followed Haynes and used tips from the forum really pleased with the outcome.
Ian’s top tips for Fiat 500 engine building!
- Always re torque the cylinder head after initial running!( more on this later)
- Always re check valve clearance.
- 15ft of heat wrap is no enough for both exhaust down pipes.
- If the wife won’t let you put the crankcase in the dish washer, Machine Mart aluminium cleaner comes a very close second!
