I have a 2018 (2.3 150hp) Ducato with the vertical style bar graph and my experience of the amber low pressure warning light was as follows:
1) Oil and filter change carried out by Fiat agent 1 year after purchase from new. Amber light had never been seen before and oil level bar graph worked perfectly.
2) Got home from after having oil changed, checked oil level and it was about 3-4mm below top notch on dipstick, so added bit more oil to bring level up to top notch.
3) Didn't drive vehicle for few days, but at next start up, no sign of bar graph on dash and amber light on. Red oil light went out straight away at start up.
4) Assumed wonky sensor and went on trip (about 300km) . At start ups after several stops along way, bar graph back and no sign of amber light. Red light went out as expected.
5) Got home and checked oil level about two days later and it was about 5-6mm or so above top notch dip stick.
6) Got me wondering if oil level was too high and if in fact amber light was something to do with oil level and not pressure as stated in owners manual. Every other vehicle I have seen or driven that has a oil can with a wavy line underneath is related to oil level and not pressure.
7) Carefully (very) partially undid sump plug and let about cup (or maybe a bit more) of oil come out. Got oil back to fractionally below top notch on dip stick.
8) Start up, bar graph showed max and no sign of amber light.
9) On all subsequent yearly oil changes, I now initially fill oil to about 12mm below top notch, leave for a few hours to let oil level stabilise and then add a bit more oil to bring level oil to just below top notch and have never seen amber light since and bar graph works perfectly.
Vehicle has now done about 27,000 km and goes well and have never seen amber light since. Normal red oil warning light goes out straight away at start up and bar graph works perfectly although I still check oil using dipstick.
So, I am still left wondering if amber light is related to oil level and not pressure, and if sump is even slightly over full, it upsets the level sensor.
All very strange.
