Technical installing new brake pads (ABS)
Raducu
Cluj-Napoca
hi guys
I have a mk2 1.2 8v, with worn front brake pads :D
I would like to change them and I need some advice related to:
1. for ABS I need brake pads with ABS sensor? (I dunno how the sensor looks like)
2. I have read that the ABS sensor is on the left wheel brake pads :confused:
if that's true I need to connect something?
I have opened only the right caliper and the job seems easy so far... I dunno about the left one with that sensor...
There is no mention of having to do anything with the wheel speed sensor when changing brake pads in the Haynes manual. I know that you don't have to worry about buying pads with sensors on them, pads are just pads!
I've done the job on my 8v non-abs and it is very easy. But anyway, as far as i know, the wheel speed sensor is part of the hub itself and you don't need to touch it to change your pads.
