Technical Injector
Technical Injector
DougieD
Cottesmore, United Kingdom.
HI There. Just wondered if anyone could help me out with a problem I'm having on my 1.4s Bravo.
Occasionally whilst driving the injection light will come on, and the car loses and regains power repeatedly. This happens for as long as the light stays on. Some times it will only last a few minutes whilst driving, other times upto half an hour and then it drives normally. Recently it has started getting more regular. I have tried redex to clean the injector which did not work, then had the injector stripped and cleaned at the same time as having the fuel filter replaced. This seemed to work for a week or so and then the problem returned. The injector still appears to be clean.
Thank you!
Dougie
I've been experiencing the same problems, have tried changing the fuel filter[:(!]. And after a diagnostic changed the lambda sensor[:(!], neither of which have worked. I did find the below site which may be able to shed a little more light on the situ though.
http://www.bravo-guide.co.uk/fix-a-bravo.htm
let me know how you get on.
