Technical Indicator wiring
Last week I removed and cleaned out my fuel tank, unfortunately I pulled off the leads going onto the indicator relay whilst doing it, at some point someone had fitted a 5 pin Nagares ITA/5-12 FLASHER unit, the pins are numbered 2*4*8*6 & 5 in the centre i have tried no end of times to 're wire the leads but cannot get it to work so I have up and bought a 3 pin old fashioned relay just with 3 pins L X & P ,however i still can't seem to get it to work, so guess what I went out & bought a Durite 0-744-36 flasher unit with 5 pins hoping it would wire up straightforward these are numbered C2 31 49 49a & C. but stil:confused::confused::confused:l can't work it out ! The wires coming out of the loom are 1-pink or mauve, 2 x light blue with black trace joined together, 1 x white or yellow with black trace and black lead that is earthed on the fuel tank sender unit. I cannot believe the units are all faulty but can anyone let me know where I am going wrong? Plus If it is possible to fit a hazard flasher I would but I will be happy just to just go out and use my indicators.:confused:confused:
