- Joined
- Aug 25, 2011
- Messages
- 150
- Points
- 39
So, now my 2006 GP won't start at all - Immobiliser, ABS, power steering batter light all illuminated when you turn the key, but absolutely none of the usual sounds you would expect when you turn the key. The heaters work on all settings, the radio works, all of that stuff is working.
To try and remedy this I have:
Is there something else I should be checking? A search suggested the fuse box may need replaced, but I checked the fuses and they weren't corroded or anything. I also didn't get any life from the car when I wiggled the fuse box, and that forum poster did.
On the verge of just binning it, but I feel like I should try all I can before I do.
- Tried the other key (both no longer work at all. Each key was previously working intermittantly for a short period)
- Cleaned all earth points and coated in copper grease
- Tested the battery
- Tried connecting a jump lead to negative battery terminal and bright part of the engine to eliminate earth
