I can't work out what will be causing this.
I turn the key (ignition light on), wait for glow plugs, start engine (starts immediately) and ignition light goes off.
If i then rev the engine, ignition light comes on - there is a bit of flicker as the revs goes on and off but basically it stays on under revs, goes off when low/idling.
I had a look at the connection to the alternator and that looked fine. I removed the connections to the battery, gave them a clean, and put them back on.
The battery was very low (but not so low that it wouldn't start the engine), so i put my battery repair/charger on it and after a day or so, it was back to full.
The battery and the alternator are new this year.
I don't understand enough about the charging circuit to understand what could be causing the light to come on.
fiat 1.9 turbo diesel
- Model
- ducato
- Year
- 1999
- Mileage
- 59999
