General I can't locate my fuel filter fiat Punto 1.2 2007
lemlem98
I have a fiat punto grande 1.2 2007 petrol and I can't seem to locate the fuel filter to replace it and fix an ongoing problem that it seems to be causing. does anyone have any ideas, I know that the fuel pump in underneath the back seats, is the filter built into this or elsewhere?
Your fuel filter is almost certainly in the tank, as part of the pump and gauge assembly. Not normally replaced, unless the pump gives up, then it all goes together.
If you hadn't found it, why do you think it is causing a problem?
Post the symptoms, and see what wisdom you get here before plunging into the tank.
Yes.. built into pump ;)
Info here:https://www.fiatforum.com/punto-mk1-guides/315620-fuel-pump-assembly-replacement-punto-1-1-spi.html?p=4257783
