General I.C.E Installs Finished At Last....
Rob_Randomcruisers.co.uk
Established member
Swindon, Wiltshire
what u all think??
chaos
Ah. Not good...
Apart from the 6x9s I like it. Seems a top job (y)
OP
OP
Established member
Swindon, Wiltshire
the 6x9s have just been put in due to not havin the cash for the clarions i want.
up front is a set of mutant conponents,
head unit, clarion one with 4hour hard drive
infinity 6x9s (to be replaced soon)
1 mono mutant amp (running both subs)
2 2channel mutant amps (1 running 6x9s, other running conponents)
2 x 12" pioneer subs
1 fused power block
1 fused earth block
1 power cap
rallycinq
Autotest Special
Lake District....Moist
I'm afraid I don't understand the stereo, but it worries me where you have the harnesses attached to. Not good, and no cage either.
I'd go back to lap 'n' diagonals.
OP
OP
Established member
Swindon, Wiltshire
there attached to were the rear belts are attached to at the top.
no cage does that matter?
if ur gonna have a crash in a cinq u eint got much to stop u anyways.
rallycinq
Autotest Special
I can see that, and its not the right place, the rear strap should be below level, not above it.
If you do roll the car, the roof will come in and you won't be able to duck out of the way
You'd be surprised how strong the wee cars are, they are designed to disperse the energy through the shell.
You'll see pictures of quite a few thumped centos on this site and they stand up well all things being considered.
rallycinq
Autotest Special
standard belts rub agaist the seats :( and ware holes in farbic
Strange, put a sleeve on the shoulder belt, the lap strap will come through where the lap strap on the harness is so shouldn't cause a problem.
If the holes in the seats are big enough you could even bring the shoulder strap through, depending on where you have your seat, of course.
OP
OP
Established member
Swindon, Wiltshire
ill have a play and see what i can do
West Yorkshire
Looks good mate.
I hope that box is properly screwed down or harnesses will be the last of your problems!!!!
My install should be finished in the next couple of weeks (ie, after pay day!)
chaos
Ah. Not good...
1 fused power block
1 fused earth block
1 power cap
IMO, you don't need that power cap :)
