General How to get the amp wire from engine cabine to the saloon
2fast4u4ever
Hi i am new at this forum and i am new with fiat. :D
I would like to ask for you're help with this problem of mine
I have a 2008 GRANGE PUNTO 1.2
I can not find a hole in the firewall to put threw the amps + cable from the engine compartment to the saloon can you plzzzzzzzzz help me?:worship::worship::worship:
i ran mine on the inside of the passenger side arch, pretty simple to do and can only be seen when the door is fully open, and doens effect the door closing properly or anything
thanx but i would like to put mine threw the firewall does anyone know how is done where is the hole and another question can ia disconnect the -(minus) cable of my batery without harming the car pc?
all you need to do is either run it through where your wiring room goes through by cutting a small hole in the gromit or drill a new hole in the bulkhead and fit a new gromit in there and put the wires through. and you do not need to disconnect the -ve terminal at all.
Undo the scuttle panel and there is a massive grommit there that needs to be cut to put a wire though.
Connector for the factory sub is crap tbh and a waste of time for anything other than the standard sub.
Disconnect the battery aswell. Its not wise to work on the car with the battery connected.
thank you very much for your help. I promise to take picture from the project and put it here step by step
