if they're pre cut why cant you do them yourself - cutting if probably the only hard thing.
if they're pre cut why cant you do them yourself - cutting is probably the only hard thing.
take out rear windows.
wash the inner window. and then spray the window with water...
place the tint on the window (it wont stick because its currently wet)
adjust the tint so it sits nice
squeeze all the water out from behind the tint with a bank card or something similar.
then re fit the rear windows and let the water dry out naturally.
jobs a goodun
https://www.fiatforum.com/punto-guides/158131-how-tint-back-side-windows-mk2-punto.htmlHow do i remove the back side windows, and how he **** do i do the boot
ok its simple do your tints yourself its going to look ****hmmmm - elaborate please? lol
jobs a goodun
DIY tinting comes up from time to time & Ive never come across a "pukka" job, as was said, in my life, & I'm old enough to be somes grandfather on here. There is nothing worse than a bad looking tint job. Get it done by a professional, they have the tools,space & the know how. Even if a self tint starts off by looking half decent, its not long until it starts to turn bad Trust me I know. There are some on here that will agree with me & indeed you have already been advised not to DIY.
Thing is what I generally find on here, not all the time mind you, but when someone has made up their mind or have issued a statement which they feel is the right way forward, well, that's it job done Get it done professionally, you know it makes sense
You make this sound so simple !! i tried it and it is inpossible, i would recoment you get someone who knows what they are doing to do it if you dont want to mess up the tint
you really dont get it do you you will never make it look good yourself! its a wast of money tryingjust take your time on it - patience is key.
if you cant manage to place the tint on the window, try spraying more water on the window and sticky side of the tint - then try to replace and squeeze water out.
i do agree - getting it done by a professional is best bet. but its also good to have a go at these things and learn, it also saves you alot of money if your on a tight budget if you do learn how to do it yourself.
you know the rear window do you just apply the tint straight onto the window because it has all the lines across it for the rear window heater?
This is why you should get a professional.......
