Re: Do you guys pay a garage to pump your tyres up too?
Pretty much as above really...
I lowered my old escort myself (no jokes,i had to start somewhere), its not hard, but i had the use of air tools (which is a BIG bonus when playing with that top bolt mentioned above too)...
As long as you are fairly handy with the spanners, well as long as you know the difference between a 10mm and a 13mm then it is fairly easy....just time comsuming!!
Best bet is to borrow the spring compressers from kwik fit or somewhere simulair, not worth buying as you are using them only once! if you give a bloke on the floor enough for a couple of drinks you can normally get away with borrowing things as long as you return them SHARPISH or else they lose their job and you will lose your knee caps!!!lol....
Good Luck
Paul R
