Technical How Do You Remove The Radio ??
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
FunkyBassman
United Kingdom.
I admit it, Im a newbie and I know next to nothing about cars but the radio in my punto has stopped working and I suspect that its speaker connectioins at the radio end and I would like to remove it to check this but I dont know how ????[:(!]
Any suggestions please ?
thanks in advance
T on Y
wll if its a mk2 punto there are sum lil holes on teh front of the radio and you need a tool called a din remvoal tool. can get them from halfords anyway the tool is a pair of metal u shape thing you slot the ends into teh holes then pull and it pulls the radio out . im not sure if mk1 puntos use the same method but i think they do. someone else with a mk1 on here will confirm or deny it i am sure
2001 Punto sporting in sprint blue with matching Mr Bump air freshner all together now mmmmmmm
mk1 has the same 2 u shaped things, i only had one so i just stuck 2 allen keys in the other side and pulled it out with fingers in the tape hole, you may be able to cut up a wire coat hanger and use that.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Go down your local pub - chances are there will be a geyzer in there who can remove it in about 5 seconds (and that includes opening the door without the keys!)
(But failing that, I too used the cocktail sticks - work a treat!)
Here come da judge...
