Technical How do you remove the courtesy light cluster in a new Bravo?
Dr Zoidberg
There's something inside the courtesy light cluster (the one in the roof by the rear view mirror) that resonates and rattles at certain engine speeds.
I really can't be arsed with yet another trip to the dealer , so before I start poking at it with a knife , has anyone had theirs apart to change a bulb and if so how do you get in there? I'm sure a few well placed bits of blu-tac will sort it out.
This is really simple.
I've done it to put white leds instead of the basic yello lights.
Juste push it towards the windscreen. Then pull it down.
There's just 2 curvy pieces of metal to hold it in position.
Almost the same as in a lancia delta.
eLearn - Contents
198000970.image
20.image
Removing ( Refitting ) 1. Move courtesy light (1a) slightly, releasing retainers (1b) using the special tool.
Tool
Description
Function
Validity
1823014000
Knife
Retainer removal
2. Disconnect electrical connections (2a, 2b) for the courtesy light.
Description
Connector
2a
FRONT COURTESY LIGHT
See G010 FRONT COURTESY LIGHT
2b
HANDS FREE MICROPHONE
See P026 HANDSFREE MICROPHONE
3. Recover the courtesy light.
198000971.image
1. If necessary, lift up cover (1a) after having released retainers (1b), then remove bulbs (1c), releasing them from the side retainers.
