- Joined
- Jan 31, 2011
- Messages
- 6
- Points
- 2
I've bought a marea liberty 1.6 (2004) a week ago.
I don't know how can i turn on it.Can you help me ?
Thanks a lot .By pressing the snowflake button...
Then you usually put the fan on 'auto' and set the temperature to whatever you desire.
Thanksss !You should be able to set it between 18 and 30 degrees and the car will try to keep the cabin at that temperature.
You then also have the "LO" and "HI" which will run the airconditioning at full to lower the temperature as much as it can, or run the heating circuit to warm the car as much as it can.
So find how warm you like the car, set it to auto, and forget it. It does all the adjustment.
If you find it doesn't cool the air when set to "LO" then the chances are it needs re-gassing, or there is a leak.
Hi there. Just thought I'd point out that there is no such thing as re-gassing. AC systems are like fridges, they are sealed and don't require any topping up. If it's low on gas then you definitely have a leak
Also when was the last time your AC was serviced? Many people forget that they need servicing and after a long period you can find poor performance.
It could just need a new receiver drier of it could have a blocked tx valve.
Plus check that your ac pump pulley engages when your ac turns on and that your revs adjust accordingly.
this suggests you can lose coolant over time: http://www.coolcaraircon.co.uk/questions.htm
Any car A/C WILL leak, meanly by the compressor seals,( but at other connections as well...) up to 10% a year is considered average.
It is NO sealed/closed system like a fridge.
So regassing every 2-5 years is absolutely normal.
I have my car serviced every two years, and although it cools fine, everytime it needs about 150-200 grams of R134A to top up the total of 750 grams.
www.autoacforum.com
