Technical Horn problem
Horn not working! I know this has arisen before, but I am trying to locate where the yellow & Black earth wire is earthed to the body when it leaves the horn ring on the steering wheel & boss, I have checked the button, it works fine, I have checked the live on the horn, that's fine, but the yellow/black lead in the wheel boss does not seem to go to earth When it leaves the boss via the copper contact ring then through the bulkhead, is there or should there be an earth connector to the body, if so where is it? I have put a meter on the copper boss ring to earth & there's no connection to earth.
. Also I would like to connect another horn in addition to the one there
( when it's working) should I use a Relay?::(:(:(
It's been a little while since I took the horn apart, but I believe the black/yellow wire leads to the back of the push button seat. Check the continuity of the black/yellow lead between horn body and the push button plate. If that's good, it could be the horn itself or the plate is not making contact. I attached the wiring diagram.
