D daccass New member Joined Feb 8, 2006 Messages 2 Points 2 Feb 8, 2006 #1 My punto mk1 75sx (97) is suffering from high revs around 1500rpm and every now and then hunts between 1500 and 2000 rpm. Does anyone have an idea what it could be? I'm getting well annoyed with it:bang: Cheers
mikstar New member Parked in the garage Joined Aug 29, 2005 Messages 220 Points 45 Location almere Feb 8, 2006 #2 you could check if the rubber bit on the end of the throttle body (where the gas cable comes out) is not cracked if it is glue it back on. and problem be fixed (if it is what i ones had sometimes it got stuck in high revs) good luck
