HID Conversion
HID Conversion
I
Ian B
Can this be done? because i've found loads on ebay out of hong kong etc at stupid rates, is it that simple to install? please help, Thanks
This has been covered a thousand times before.
Install guide is here:http://www.insworld.co.uk/index.php?page=bravohidinstall
H1 is the bulb type you need. 4500K-6000K is the bulb range to go for.
Easy to fit and ideally you need Marea poly-eliptical headlights otherwise the standard lenses will put the light in the wrong direction.
Longest Serving BOO Member
Bravo: Nov 01 80SX / 75,000 miles
Coupe: Feb 97 20V N/A / 135,000 miles
Yes the "hong kong fleabay ones" are fine i bought a set.
Took about 30 minutes to fit but you do need some marea poly type lights ( as insomnia mentioned)
Also they are not actually legal in the uk saying that mine have been in for a year and never had any problems.
Good luck!!
A
1
554
Daniel
J
57
3K
Dark Lurker
K
9
418
Sabre 23
S
2
301
M
